AE3 OLED Breakout
The AE3 OLED Breakout pairs the OpenMV AE3 with a 128 × 128 RGB OLED, a 5‑way joystick, and a 10‑pin ARM SWD header for stand‑alone preview, simple input, and JTAG/SWD debug.
AE3 OLED Breakout
For full datasheet, photos, and ordering see the AE3 OLED Breakout product page.
Highlights
  • 128 × 128 RGB OLED driven by an SSD1351 controller over SPI.
  • AS90R 5‑way joystick with a centre push button, exposed on the P4/P5 I²C bus.
  • Reset button and recovery switch for secure‑enclave UART access.
  • OLED disconnect switch to electrically remove the panel from the SPI bus.
  • Two Qwiic connectors on the same P4/P5 I²C bus.
  • ARM 10‑pin Cortex Debug header for SWD/JTAG debugging.
  • Four ground hook test points.
Four corner M1.6 mounting holes let you bolt the breakout down to an enclosure or fixture.
Pin reference
All AE3 signals on the breakout are taken from the B2B header on the bottom of the AE3 and brought out to two side pin headers — P0–P5 on one side, P6–P9 on the other — both 3.3 V referenced. The full alt function list for each pin lives on the OpenMV AE3 page; the breakout uses the pins as follows:
Reference
AE3 features
Breakout use
OLED SPI MOSI
free
OLED SPI SCLK
OLED SPI CS
Joystick / Qwiic I²C SCL
Joystick / Qwiic I²C SDA
NRST
Press the on‑board RESET button or pull to GND to reset the AE3
I2C1 SDA / UART3 CTS / TIM9 T0
free
I2C1 SCL / UART3 RTS / TIM9 T1
OLED RESET
I3C SDA / UART3 RX / TIM5 T0 / ADC ch S10
OLED DC (register select)
I3C SCL / UART3 TX / TIM5 T1 / ADC ch S11
Joystick IRQ (active low on state change)
3.3V rail
Powers the OLED, joystick expander, and Qwiic devices
GND rail
Common ground
The recovery switch flips an internal USB mux on the AE3: the AE3’s own USB pins are disconnected from the USB‑C port, and a USB‑to‑serial converter on the secure‑enclave UART is connected to the port in their place. With the switch engaged, host‑side Alif tools can talk to the secure enclave to reprogram the AE3’s bootloader. Leave the switch disabled for normal operation so the USB‑C port acts as the AE3’s USB.
The OLED enable switch has to be on for the OLED to work — it gates power to the panel and connects the OLED control pins (P0, P2, P3, P7, P8) through to the AE3’s GPIO. With the switch off only P4, P5, and P9 stay wired through. The current switch state shows up on the joystick expander as bit 0x40 — the raw expander pin reads low when the switch is enabled.
Qwiic headers
Two Qwiic 4‑pin JST‑SH 1.0 mm connectors sit on the breakout and share the same P4/P5 I²C bus as the on‑board joystick expander, so additional Qwiic devices must avoid the joystick expander’s address (0x63).
Signal
1
+3.3 V
3
SDA (P5)
4
SCL (P4)
JTAG header
The 10‑pin 1.27 mm ARM Cortex Debug header on the breakout is wired straight to the AE3’s SWD/JTAG lines. All signals are 1.8 V referenced — use a level‑shifting probe or one whose target voltage tracks VCC_REF (pin 1).
Signal
1
VCC_REF (+1.8 V)
2
TMS (SWDIO)
3
+1.8 V
4
TCK (SWCLK)
5
TDO (SWO)
7
key (no pin)
8
TDI
9
DEBUG_RST_N (JTAG/debug reset — separate from the system NRST)
Usage
Drive the OLED through display.SPIDisplay with an SSD1351 controller instance. Stream camera frames to the 128 × 128 panel:
                         controller=display.SSD1351())
    lcd.write(csi0.snapshot(),
Read the 5‑way joystick through the frozen pca9674a.PCA9674A driver. The expander asserts P9 on state changes, so wire an IRQ callback that latches the new button state. The buttons are active‑low on the expander; the code below XORs the read with 0xFF so a set bit in state means pressed:
Bit
Direction
0x01
Joystick right
0x02
Joystick up
0x04
Joystick left
0x08
Joystick down
0x10
Joystick centre push
0x40
OLED enable switch (set in state when the OLED is enabled)
from pca9674a import PCA9674A
state = 0
cursor_x = 0
cursor_y = 0
def read_expander(pin):
    global exp, state
    state = exp.read() ^ 0xFF
def update_cursor():
    global cursor_x, cursor_y
    if state & 0x01:  cursor_x += 2     # Right
    if state & 0x02:  cursor_y -= 2     # Up
    if state & 0x04:  cursor_x -= 2     # Left
    if state & 0x08:  cursor_y += 2     # Down
    if state & 0x10:                    # Centre
        cursor_x = 0
        cursor_y = 0
    update_cursor()
