Arduino Giga R1 WiFi#
The Arduino Giga R1 WiFi is a 101 × 53 mm Mega‑form‑factor board built around the STMicroelectronics STM32H747XI — a dual‑core SoC combining a Cortex‑M7 at 480 MHz with a Cortex‑M4 at 240 MHz. The OpenMV firmware runs entirely on the M7 core. The Giga adds a 22‑pin Arducam camera flex connector, a MIPI‑DSI connector for the Arduino Giga Display Shield, and a 3.5 mm stereo audio jack to the standard Arduino Mega header layout.
For full datasheet, photos, and dimensions see the Arduino Giga R1 WiFi product page.
  • STMicroelectronics STM32H747XI dual Cortex‑M7 (480 MHz) + Cortex‑M4 (240 MHz). OpenMV firmware runs on the M7 core only; the M4 core is exposed through openamp for Inter‑Processor Communication.
  • 8 MB external SDRAM plus 2 MB internal flash and 16 MB external QSPI flash.
  • 22‑pin Arducam‑compatible camera flex connector (J6) — driver support for OV5640 (5MP), OV7670, GC2145, HM01B0, and HM0360 sensor modules.
  • MIPI‑DSI display connector (J5) for the Arduino Giga Display Shield (480×800 capacitive touch panel) plus an LTDC RGB display engine for advanced carriers.
  • 3.5 mm audio jack with stereo line‑out and mic in.
  • USB‑C (full‑speed) for power / serial / programming.
  • User I/O on the Mega‑style headers — D0–D75 (digital), A0–A11 (analog), DAC0/DAC1 (DAC outputs), CAN_RX/CAN_TX (FDCAN2), and the inner-row SDA1/SCL1 I²C pair. A separate 6‑pin SPI1 header on the front of the board breaks out CIPO/COPI/SCK (D89/D90/D91).
  • JTAG / SWD broken out on the top‑side debug header for advanced debug.
Arduino Giga R1 WiFi Pinout
The Arduino Mega‑style headers expose 76 digital pins (D0–D75), 12 analog pins (A0–A11), two DAC outputs (DAC0/DAC1), a secondary I²C pair (SDA1/SCL1), and an FDCAN2 pair (CAN_RX/CAN_TX). A separate 6‑pin SPI1 header on the front of the board breaks out CIPO/COPI/SCK (D89/D90/D91).
Reference
TIM8 CH1 / UART8 TX
TIM1 CH1 / TIM8 CH3N
TIM8 CH2 / SPI5 MOSI
TIM8 CH2N / SPI5 MISO
TIM12 CH1 / SPI5 SCK
D14
D15
D16
D17
UART4 RX (Serial3)
D18
USART2 TX (Serial4)
D19
D20
D21
I2C2 SCL
D22
D23
GPIO / SPI6 SCK
D24
GPIO / SPI6 MISO
D25
D26
D27
D28
D29
D30
D31
D32
D33
D34
D35
D36
D37
TIM8 CH2
D38
TIM8 CH2N
D39
D40
TIM15 CH2 / SPI4 MOSI
D41
D42
D43
D44
D45
D46
TIM8 CH3N
D47
SPI3 MOSI
D48
TIM8 CH3 / SPI5 SCK
D49
D50
D51
TIM15 CH1 / SPI4 MISO
D52
D53
D54
TIM8 CH1 (camera DCMI VSYNC)
D55
I2C3 SDA (camera DCMI HSYNC)
D56
D57
D58
TIM8 CH3 (camera DCMI D7)
D59
TIM8 CH2 (camera DCMI D6)
D60
GPIO (camera DCMI D5)
D61
D62
SPI1 SCK (camera DCMI D3)
D63
D64
TIM5 CH1 (camera DCMI D1)
D65
TIM12 CH2 (camera DCMI D0)
D66
D67
GPIO (camera power‑down — claimed when camera is active)
D68
D69
D70
SPI2 SCK
D71
TIM8 CH4 / SPI2 MISO
D72
SPI2 MOSI
D73
D74
D75
A0 / D76
ADC12 IN4
A1 / D77
ADC12 IN8
A2 / D78
A3 / D79
A4 / D80
ADC12 IN13 / SPI2 MOSI
A5 / D81
ADC123 IN12 / SPI2 MISO
A6 / D82
ADC123 IN10
A7 / D83
A8
ADC3 IN0 (analog only)
A9
ADC3 IN1 (analog only)
A10
ADC12 IN1 (analog only)
A11
ADC12 IN0 (analog only)
DAC0 / A12 / D84
DAC1 OUT1 / ADC12 IN18 (audio jack line‑out L)
DAC1 / A13 / D85
DAC1 OUT2 / TIM2 CH1 / SPI1 SCK / ADC12 IN19 (audio jack line‑out R)
D89
SPI1 MISO (CIPO on the front SPI header)
D90
SPI1 MOSI (COPI on the front SPI header)
D91
SPI1 SCK (SCK on the front SPI header)
CAN_RX / D93
CAN_TX / D94
SDA1 / D102
I2C4 SDA (display touch / camera control bus)
SCL1 / D101
I2C4 SCL (display touch / camera control bus)
press the on‑board RESET button or pull to GND to reset
A8–A11 are analog‑only pads on the STM32H747’s _C pins — they have no GPIO function and can only be read through the ADC.
Power pins#
Mega header pins:
  • VIN — 6–32 V input. Powers the board through the on‑board buck regulator.
  • +5V — 5 V rail fed from USB via a diode or the on‑board buck regulator.
  • +3V3 — main 3.3 V rail.
  • IOREF — reflects the I/O voltage of the board (3.3 V).
  • AREF — analog voltage reference for the ADC pins. Defaults to 3.3 V; drive externally to use a different reference.
  • OFF — pull to GND to turn off the +3.3 V rail and shut the system down.
  • VRTC — 3.0 V coin‑cell input (3.3 V max) that keeps the on‑chip RTC running while the rest of the board is powered off.
The Giga R1 can be powered through any of these paths:
  • USB‑C — supplies 5 V to the on‑board buck regulator.
  • VIN pin — drive a regulated 6–32 V supply directly.
Use the battery life estimator to model how long the Giga R1 will run on a battery for a given active / deep-sleep duty cycle.
Recovery and debug pins#
  • RESET — both an exposed pin on the power header and a momentary switch on the top of the board, tied to the SoC’s NRST line. Pull to GND or press the button to reset.
The Giga R1 uses Arduino’s standard double‑tap reset to enter Arduino’s bootloader. Quickly press the RESET button twice — the board re‑enumerates over USB as a DFU device and OpenMV IDE can flash a new firmware image.
If the bootloader is missing entirely, hold the BOOT0 button while pressing RESET to force the SoC into ROM bootloader mode.
The STM32 SWD signals are exposed on the 10‑pin 1.27 mm Cortex Debug header on the front of the board. Wire them up via a SEGGER J‑Link, ST‑Link, or any standard ARM JTAG/SWD probe. All debug signals are 3.3 V referenced.
Onboard peripherals#
LEDs#
The Giga R1 has a single user RGB LED, software‑controllable through machine.LED:
A separate power LED on the board lights whenever the +3.3 V rail is up and is not user‑controllable.
Camera connector (J6)#
J6 is a 22‑pin Arducam‑compatible camera flex connector. Plug in any of the supported sensor modules and the firmware probes them automatically through the csi — camera sensors module:
Supported sensors:
  • OV5640 — 5 MP colour, up to QSXGA (2592 × 1944).
  • OV7670 — 0.3 MP colour, up to VGA (640 × 480).
  • GC2145 — 2 MP colour, up to UXGA (1600 × 1200).
  • HM0360 — VGA (640 × 480) monochrome.
While the camera is initialised, the following Mega header pins are claimed by the firmware and cannot be used:
Reason
D54–D65
DCMI data + sync signals on the camera flex connector
D57
TIM1 CH3 — camera master clock
D66
Camera reset GPIO
D67
Camera power‑down GPIO
SDA1 / SCL1
I²C 4 — shared with the camera; bus is usable but avoid the sensor’s I²C address
Machine learning#
ml — Machine Learning runs quantised TFLite models on the Cortex‑M7 with CMSIS‑NN kernels — fast enough for compact detectors at a few frames per second. Models on the read‑only /rom filesystem load directly from flash without copying to RAM. Here’s a 128×128 BlazeFace detector overlaying the detected face and its six landmarks on every frame:
M4 core#
Display (J5)#
J5 is a MIPI‑DSI connector for the Arduino Giga Display Shield — a 480 × 800 capacitive touch panel built around the ST7701 panel driver and the GT911 touch controller. Both drivers ship frozen with the firmware. Use display — display driver to push framebuffers and gt911.GT911 for touch input.
The example below mirrors the camera into a portrait 800 × 480 display window and overlays each touch contact as a coloured circle:
from gt911 import GT911
IMG_OFFSET = 80
touch_detected = False
                 (0, 255, 255), (255, 255, 0))
lcd = display.DSIDisplay(
    framesize=display.FWVGA,
    portrait=True,
    refresh=60,
    controller=display.ST7701(),
touch = GT911(
    I2C(4, freq=400_000),
    reset_pin="D71",
    irq_pin="D70",
    touch_points=5,
    refresh_rate=240,
    reverse_x=True,
    if touch_detected:
            img.draw_circle(
                (points[i][0] - IMG_OFFSET,
                 points[i][1],
                 points[i][2] * 3),
                thickness=2,
The Giga Display Shield uses the same I²C 4 bus (SDA1/SCL1) as the camera, D74 for the LCD backlight enable, D70/D71 for the GT911 touch IRQ and reset, and D68/D69 for the DSI panel’s TE and RESET signals.
Microphone (Display Shield)#
The Arduino Giga Display Shield carries a digital microphone wired to the STM32H747’s DFSDM peripheral (mic clock on D75, mic data on D73). The microphone is captured through audio — Audio Module. Each buffer arrives as signed‑16‑bit PCM bytearray, ready to feed into ulab/numpy for DSP:
IMU (Display Shield)#
The Arduino Giga Display Shield carries a Bosch BMI270 6‑axis IMU (3D accelerometer + 3D gyroscope) on the same I²C 4 bus at address 0x68. Use the community micropython_bmi270 driver to read it:
sensor.load_config_file()
    gx, gy, gz = sensor.gyro
    print(ax, ay, az, gx, gy, gz)
The full register map is in the BMI270 datasheet.
RGB LED (Display Shield)#
The Arduino Giga Display Shield carries an on‑board RGB LED driven by an ISSI IS31FL3197 3‑channel LED driver on the same I²C 4 bus. The driver’s AD pin is tied to GND, so it sits at I²C address 0x50. Use the community IS31FL3197 driver to control the LED:
The full register map is in the IS31FL3197 datasheet.
Wi‑Fi#
Bluetooth#
Bus reference#
GPIO#
Use machine.Pin to read or drive any of the silkscreened pins. Outputs are 3.3 V CMOS and can sink/source up to 20 mA per pin (140 mA total across the whole header).
UART#
Arduino name
Serial1
UART6
D14
D15
Serial2
D16
D17
Serial3
UART2
D18
D19
Serial4
I²C#
D21
D20
SCL1
SDA1
Bus 2 (D20/D21, the silkscreened SCL/SDA) is the default Arduino Wire bus. Bus 4 (SCL1/SDA1) is shared with the camera and the Giga Display Shield’s GT911 touch controller — user devices on this bus must avoid the following addresses (7‑bit):
  • 0x3C — OV5640 / GC2145
  • 0x24 — HM01B0 / HM0360
  • 0x21 — OV7670
  • 0x5D — GT911 touch controller (Giga Display Shield)
SPI#
SPI1
D90
D89
D91
SPI5
SPI1 is exposed on a dedicated 6‑pin header on the front of the board. SPI5 is exposed on the silkscreened COPI/CIPO/SCK labels on D11/D12/D13.
Pinout of the front 6‑pin SPI1 header (J7):
Signal
1
D89 (CIPO)
2
+5V
3
D91 (SCK)
4
D90 (COPI)
5
NRST
6
CAN (FDCAN)#
CAN is not enabled in the current firmware for this board, so neither machine.CAN nor pyb.CAN is available.
D94
D93
ADC#
The Giga R1 exposes twelve 12‑bit ADC channels on A0–A11, all 3.3 V referenced — read_u16 returns 0–65535 across 0–3.3 V at the pin. A8–A11 are analog‑only _C pads with no GPIO peripheral:
A7 is also wired to the microphone input on the 3.5 mm TRRS audio jack — when a headset is plugged in, ADC("A7") reads the analog mic signal directly.
DAC#
Two 12‑bit DAC channels are exposed on DAC0 and DAC1 through pyb.DAC. Both are wired to the 3.5 mm TRRS audio jack as the left and right line‑out channels:
left  = DAC("DAC0")
right = DAC("DAC1")
right.write(int(0.5 * 255))
PWM#
Timer / channel
TIM4 CH2 / TIM17 CH1N
TIM1 CH3N / TIM8 CH1
TIM3 CH1
TIM4 CH3 / TIM16 CH1
TIM4 CH4 / TIM17 CH1
TIM1 CH2N / TIM8 CH2
TIM1 CH2 / TIM8 CH2N
TIM12 CH1
D15
TIM3 CH2 / TIM8 CH2
D16
TIM8 CH1N
D20
D37
TIM8 CH2
D38
TIM8 CH2N
D40
TIM15 CH2
D46
TIM8 CH3N
D48
TIM1 CH1N / TIM8 CH3
D51
TIM15 CH1
D54
TIM8 CH1
D56
TIM3 CH1 / TIM13 CH1
D57
TIM1 CH3 / TIM8 CH1N
D58
TIM8 CH3
D59
TIM8 CH2
D61
TIM8 CH2N
D63
TIM5 CH2
D64
TIM5 CH1
D65
TIM12 CH2
D68
TIM3 CH1 / TIM8 CH1
D69
TIM5 CH4
D71
TIM8 CH4
D78 / A2
D79 / A3
D83 / A7
TIM2 CH1 / TIM5 CH1
D85 / A13
TIM2 CH1 / TIM8 CH1N
TIM1 is reserved for the camera master clock when the camera is initialised through csi — camera sensors. Pins whose only PWM function is on TIM1 — D1, D10, D11, D12 — cannot be PWM‑driven while the camera is active. The other listed pins all have non‑TIM1 alternates.
Several pins share timer channels:
  • TIM2 CH4 is on D2 and D20.
  • TIM2 CH1 is on D83/A7 and D85/A13.
  • TIM3 CH1 is on D7, D56, and D68.
  • TIM3 CH2 is on D5 and D15.
  • TIM4 CH2 is on D0 and D6.
  • TIM5 CH1 is on D64 and D83/A7.
  • TIM5 CH4 is on D2 and D69.
  • TIM8 CH1 is on D4, D54, and D68.
  • TIM8 CH1N is on D5, D16, D57, and D85/A13.
  • TIM8 CH2 is on D11, D15, D37, and D59.
  • TIM8 CH2N is on D12, D38, D61, and D78/A2.
  • TIM8 CH3 is on D48 and D58.
  • TIM8 CH3N is on D10, D46, and D79/A3.
  • TIM15 CH1 is on D3 and D51.
  • TIM15 CH2 is on D2 and D40.
Pick one consumer per timer channel.
Software bit‑banged buses#
Thermal sensor (off‑board)#
The fir driver only talks to the sensor over I²C 1 — wire the module to D8 (SCL) and D9 (SDA).
Timing#
time#
Virtual timers#
Real‑time clock#
machine.RTC keeps wall‑clock time across resets — and across full power‑off when a coin cell is connected to the VRTC pin:
Watchdog#
Boot and runtime info#
Firmware update (DFU)#
The Giga R1 uses Arduino’s standard double‑tap reset to enter Arduino’s bootloader. Quickly press the RESET button twice — the board re‑enumerates over USB as a DFU device and OpenMV IDE can flash a new firmware image. If the bootloader is missing entirely, hold the BOOT0 button while pressing RESET to force the SoC into ROM bootloader mode.
Filesystem and boot order#
The Giga R1 firmware mounts up to two filesystems on boot:
When connected over USB, /flash also enumerates as a USB mass‑storage drive on the host, letting you edit boot.py, main.py, and any other files directly. Eject the drive before resetting the board so the host flushes its cached writes.
Because the OS treats the drive as a passive block device, files created or modified by code running on the camera will not show up until the host re‑mounts the drive. If both the OS and the camera write the same filesystem at the same time, the OS will win and overwrite changes made by the camera.
Storage sizes#
The Giga R1 ships with:
Hard‑fault indicator#
Software libraries#
See the library index for the full list of modules — including which ones are unique to the Giga R1 build.
