13.1.20. The model zoo and NPU conversion#
The IDE ships with a library of pretrained machine-learning models – face detection, person detection, object detection, pose estimation, and more – kept current through the IDE’s resource updates. Tools → Machine Vision → Open Model Zoo browses it: select a model to see its description page alongside the file tree, and tick the filter to narrow the list to models that fit your board.
The Model Zoo browser: the model tree on the left with a model selected, its description page on the right, and the filter-by-board-type checkbox at the bottom
The Model Zoo browser with a model selected and its description page open.#
Choose a model and the IDE copies it out ready to run: it converts the model for the target board’s NPU accelerator when the board has one, copies the matching labels file alongside it, and defaults the destination to the connected camera’s drive. From there the script side is one ml.Model constructor call away. The same browser is reachable from inside the ROMFS editor, which is the better destination for models on boards that have ROMFS – models in ROMFS execute straight from flash without a RAM copy.
13.1.20.1. Converting other models#
Tools → Machine Vision → Convert Model for NPU runs the same conversion on a model from anywhere else – one trained with Edge Impulse or Roboflow, exported from a training framework, or downloaded. NPU-equipped boards each have a vendor compiler that the IDE bundles and drives: Ethos-U NPUs use Vela, and ST Neural-ART NPUs use ST Edge AI. The tool takes the target board from the connected camera (or asks when none is connected) and takes the model file from you. A model that is already converted is recognized and just copied, and when the selected board has no NPU the tool says so and skips the conversion – an unconverted model still runs on those boards, on the CPU.
On NPU boards the conversion is not optional: at best an unconverted model falls back to the CPU and runs many times slower, and on some boards it will not run at all. The ROMFS editor and the model zoo apply the conversion automatically; this menu entry exists for models that arrive by other routes.
See also
The machine learning chapter for running models with the ml module and training custom ones.
