13.1.12. Standalone terminal windows#
Tools → Open Terminal opens independent terminal windows – each one a miniature OpenMV IDE session in its own window, with a frame buffer viewer, a histogram, and an interactive terminal, connected over a transport of your choosing. The main window’s connection is unaffected, so a standalone terminal lets you watch a second camera while the first stays connected, or debug a camera on the far side of a network.
A standalone terminal window over a serial port: the interactive terminal on the left with its run / stop / reset toolbar, the frame buffer and histogram on the right – they light up when the camera streams frames in-band.#
New Terminal asks for one of three transports:
Serial port – any serial port at any baud rate (default 115,200). This covers a second camera’s USB port, a camera wired up over a USB-to-UART bridge, a Bluetooth serial link (which shows up as an ordinary serial port), or any non-OpenMV serial device that needs a terminal. On a USB port the baud rate does not limit the speed – data always moves at the USB link’s speed – but on a camera’s USB port avoid 921,600 and 12,000,000, which switch the camera from the REPL into the IDE’s debug protocol.
TCP – connect to a server at a chosen host and port, or listen as one on a chosen port.
UDP – the same pair of roles, over UDP.
The IDE remembers the last ten configurations and lists them in the Open Terminal submenu for one-click reopening; Clear Menu forgets them.
Unlike the main window’s output-only pane, a standalone terminal is fully interactive: it is a REPL. Type at the prompt and Python executes on the connected camera line by line, with history and tab completion provided by MicroPython itself. The toolbar adds one-click equivalents of the common control sequences – run the current editor script, stop the running script, and soft reset – and the same clear, save, and wrap controls as the main terminal pane.
The frame buffer above the terminal is live too. When the connected camera streams compressed frames in-band – embedded in the same stream as its print output – the terminal decodes and displays them, and the Record and Zoom buttons work exactly as they do in the main window. That combination is the IDE’s network-debugging story: a camera that exposes its REPL over Wi-Fi gets the full edit-run-preview loop with no USB cable involved.
13.1.12.1. Streaming frames in-band#
The encoding the terminal understands is simple: a 0xFE byte opens a frame, a second 0xFE closes it, and every payload byte between them has its top bit set and carries six bits of the compressed image – three image bytes become four payload bytes. Plain text never uses those byte values, so frames and print() output share the stream without colliding: the terminal shows the text and displays the frames.
The script below captures, converts each frame to JPEG, and prints it in that form. The bit-packing runs through ulab (which has no shift operators, so the shifts are written as multiplies and divides), and is fast enough to keep up with the camera:
import sys
def encode_for_ide(data):
n = len(data)
n3 = n - (n % 3)
m = (n3 // 3) * 4
out[0] = 0xFE
out[-1] = 0xFE
if n3:
b0 = src[0:n3:3]
b1 = src[1:n3:3]
b2 = src[2:n3:3]
if n % 3 == 2:
elif n % 3 == 1:
return out
This works in a standalone terminal because REPL printing waits: the camera blocks until the terminal has taken the data, so every byte of the frame arrives, and a JPEG moves quickly over a USB full-speed or high-speed link. The same script works unchanged over a TCP terminal, which is the network-debugging path above. The one place it does not work is the IDE’s main debug connection, whose output channel resets itself on overflow instead of waiting – there the frame buffer viewer already shows the camera’s frames natively, so nothing is missed.
