13.1.7. The pane views#
The pane below the frame buffer viewer shows more than the histogram. A selector at the left of its title bar switches it between five views, each a different instrument pointed at the connected camera:
  • Histogram – the pixel statistics of the current frame, covered on its own page.
  • Board Info – what the connected camera is.
  • Memory – how much of its RAM the script is using, live.
  • Channels – the values and controls the script publishes, covered on its own page.
  • Statistics – what the link between the IDE and the camera is doing.
The selection is remembered across sessions. Only the view that is showing does any work: switch away from the histogram and its computation stops until you switch back, so leaving the pane on Memory or Channels costs the preview nothing. Each view explains itself when it cannot show anything – no camera connected, or a camera whose firmware does not report the data – and the Board Info, Memory, and Statistics views need a camera running the v2 debug protocol (firmware 5.0.0 or newer).
13.1.7.1. Board Info#
Board Info is the camera’s identity card: the board type and attached sensor, the serial port, the firmware, protocol, and bootloader versions, the CPU and device ids, the USB vendor and product ids, the sizes of the stream buffer, frame buffer, flash, and RAM, and a row of yes / no capabilities – GPU, NPU, ISP, video encoder, JPEG codec, DRAM, CRC, performance counters, profiler support, Wi-Fi, Bluetooth, SD card, Ethernet, high-speed USB, and multiple cores. It is the first place to look when a support question starts with “which board is this exactly”, and the text is selectable, so you can copy the lot into a bug report.
The Board Info view listing an OpenMV N6 with a Lepton sensor: board, sensor, port, firmware, protocol and bootloader versions, CPU and device ids, USB id, buffer sizes, and the yes / no capability rows
Board Info for an OpenMV N6 with a thermal sensor.#
13.1.7.2. Memory#
Memory plots the camera’s memory use while a script runs: one graph for the MicroPython garbage-collected heap and one for each of the firmware’s memory pools, each with its used / total, free, and peak figures underneath and a line marking the highest use seen since connect. The graphs scroll with time, so the heap’s normal sawtooth – allocations climbing until the garbage collector runs – is obvious at a glance, a slow leak shows up as a staircase, and a frame-sized allocation as a spike on every loop. The pools also report Persist, the memory held by long-lived allocations such as frame buffers, as distinct from what the script churns through.
The Memory view with the GC heap graph showing a sawtooth of allocations and collections, and a memory pool graph below, each with used / total, free, persist, and peak figures
The Memory view: the heap’s sawtooth and a memory pool, with their figures.#
13.1.7.3. Statistics#
Statistics is the dashboard for the debug protocol itself. The Device and Host sections count the packets sent and received on each side, checksum and sequence errors, retransmits, and transport errors, and the Channels table between them lists every channel the camera has registered with its event count and event rate. It is the diagnostic view for a connection that misbehaves: a stream that stalls, a camera that drops frames over a long cable, or a script publishing so fast the link cannot keep up – the counters show which side is losing and how badly.
The Statistics view with the device counters, the per-channel event table, and the host counters stacked in the pane
The Statistics view: protocol counters for each side and per-channel event rates.#
