13.1.4. Running scripts#
The start button – the green arrow below the connect button, or Ctrl+R – sends the script in the current editor tab to the connected camera and runs it. While a script runs, the start button becomes a stop button that halts it. Those two buttons are the core loop of all development on the camera: edit, start, watch, stop, edit again.
Two details of that loop matter. First, the script is sent to the camera’s RAM and executed there – starting a script writes nothing to the camera’s storage, and the script is gone after a reset. Second, what runs is the current editor tab, exactly as shown, saved or not. There is no separate upload step and no stale copy on the camera to fall out of sync with your editor. The one liberty the IDE takes is stripping the comments out of the copy it sends: the script’s source sits in the camera’s RAM while it compiles, and the comment-heavy examples are smaller without them. Lines are never removed, only emptied, so line numbers in a traceback still match your editor.
While a script runs, its print() output streams into the serial terminal and every frame it captures appears in the frame buffer viewer, and anything it publishes as a channel appears in the Channels view. When a script raises an unhandled exception, the traceback prints to the serial terminal, the IDE jumps the editor to the offending line and marks it in red with the error beside it – for a multi-file application it first opens the named file from the camera’s drive. The mark clears when you edit the file, run again, or disconnect. When a script stops, by Stop or by crashing, the Channels view keeps the last values it published on screen until the next script starts.
13.1.4.1. Making a script permanent#
To make the camera run a script without the IDE – on power-up, standalone, in the field – store the script on the camera as main.py. Tools → Save open script to OpenMV Cam (as main.py) writes the current editor tab to the camera’s drive under that name, offering on the way to strip comments and compress whitespace – which shrinks the file but ships an unreadable copy – and Tools → Reset OpenMV Cam restarts the camera so it boots into the stored script. Together they are the deploy step: from then on the camera runs your script whenever it has power, IDE or not.
While a reset camera is running its stored main.py, the IDE can still connect to it – with Stop Script on Connect/Disconnect on (the default), connecting halts the stored script and hands control back to the editor.
See also
Freezing scripts into the firmware for what main.py means in the camera’s boot sequence, and for moving a finished application out of editable storage entirely.
13.1.4.2. The camera’s drive#
The camera’s flash filesystem (and SD card, when one is inserted) mounts on the host as a USB flash drive. Tools → Open OpenMV Cam Drive folder opens it in your file manager. This is where you copy library modules, model files, and assets the script imports or loads, and where you retrieve the images and logs it saved. The drive path also appears in the status bar.
Files a script creates do not show up on the host right away: the host caches the filesystem from the moment the drive mounts, so a snapshot saved by the running script stays invisible until the drive remounts. Tools → Reset OpenMV Cam remounts it – the quick way to get at what the script just wrote.
One caution: the camera and the host share that filesystem, and simultaneous writes from both sides can corrupt it. Copy files while no script is writing to storage, and eject cleanly before pulling the card.
