13.1.11. The serial terminal#
The pane along the bottom of the main window is the serial terminal: everything the running script writes to standard output – every print(), every warning, every traceback – streams into it live. It is the script’s voice during development, and reading it is half of debugging. Open and close it from its button in the bottom status bar; like the other panes, you can drag it larger or collapse it entirely.
The serial terminal showing a script's FPS prints, the traceback that ended it, and the camera's banner
The serial terminal: the script’s prints, the traceback that ended the script, and the camera’s banner after the stop.#
The terminal keeps a deep scrollback (100,000 lines), and its toolbar offers a filter box that narrows the view to lines matching a search, a save button that writes the whole buffer to a text file, and a wrap toggle for long lines. The text zooms with Ctrl+scroll like the editor. Scroll up and the auto-scroll pauses so you can read earlier output while the script keeps printing; scroll back to the bottom and it resumes.
The pane is output-only – it displays what the camera prints but does not accept typed input. For an interactive REPL prompt on the camera, open a standalone terminal window instead.
A debug-logging toggle in the toolbar interleaves the camera debug protocol into the terminal, one emoji-tagged line per message, at a few levels of detail. It is a diagnostic aid for a connection that misbehaves – a camera that will not connect, or a stream that stalls – and off by default; leave it off for normal work, where it only adds noise.
Tracebacks are wired into the editor. When a script dies with an unhandled exception, the IDE parses the traceback as it prints, jumps the editor to the offending line, marks it in red with the error text beside it, and – when the failing file is a module on the camera’s drive rather than the open script – opens that file at the failing line. You go straight from “it crashed” to the line that crashed.
