13.1.16. Third-party repositories#
The IDE ships OpenMV’s own boards, firmware, examples, machine-learning models, and editor stubs, but it can load the same kinds of content from other companies as well – a board a partner built, the firmware that runs on it, examples and models tuned for it, and code completion for the APIs that firmware adds. These arrive as third-party repositories: folders of content the IDE merges with its own and keeps up to date.
This page has two audiences. Most of it is for the person installing and managing a repository someone else published. The last section, authoring a repository, is for the vendor building one.
13.1.16.1. The Third Party Repositories page#
Everything is managed from Edit → Preferences → OpenMV → Third Party Repositories. The table lists every installed repository and, for each, its display name, its short id, whether it is Built-in or User, the installed version of each kind of content it provides – firmware, examples, models, stubs – and the URL it updates from.
Built-in means the repository was placed into the application’s own directory by an installer the vendor shipped, the way a driver package adds files to a program. User means you installed it yourself from a URL. The only practical difference is that you cannot remove a built-in repository from the IDE – it is removed by uninstalling whatever put it there – so the Remove button is disabled for it.
13.1.16.2. Installing a repository#
Install from URL asks for the address of a repository’s config.json – the small manifest file the vendor publishes – and installs everything it points to. Paste the URL the vendor gave you; the IDE downloads the manifest, fetches the firmware, examples, models, and stubs it lists, and verifies each download. Installing, removing, and updating a repository all take effect after a restart, so the IDE offers to restart when the install finishes.
A vendor can also distribute a repository as an installer that drops it straight into the application directory, in which case it is simply present as a Built-in row the first time you open the page – nothing to install.
13.1.16.3. Keeping repositories updated#
A repository that carries an update URL is checked each time the IDE launches. When newer content is available the IDE tells you what – listing each repository and the versions involved – and offers to install it, all in a single prompt. Check for Updates runs the same check on demand.
13.1.16.4. Priority and overrides#
Repositories are an ordered list, highest priority at the top, and Move Up and Move Down reorder the selected one. Order matters only when two sources provide the same thing: a board with the same USB identifier, or an example, model, or stub with the same name. When that happens the higher entry wins, and every repository wins over OpenMV’s built-in content. This is deliberate – it is how a vendor supplies their own firmware for a board that shares an OpenMV board’s USB identifier, replacing the stock firmware the IDE would otherwise offer for it, or replaces a stock example with one written for their hardware.
Because an override silently changes what a familiar name does, the page never hides one. The Override warnings panel lists every override in effect – which repository’s board, example, model, or stub is overriding which – and the same list appears once as a message the first time a repository is seen. If a board, example, or model is not behaving the way OpenMV’s documentation describes, this panel is the first place to look.
13.1.16.5. What a repository provides#
The four kinds of content each appear in their usual place in the IDE, so once a repository is installed there is nothing new to learn:
  • Boards and firmware. A repository’s board behaves exactly like an OpenMV board – it is recognized on connect, its type shows in the status bar, and its firmware updates through the IDE, including the Install the Latest Development Release path. See Firmware updates and recovery.
  • Examples. A repository’s examples appear in File → Examples, merged into the category tree: an example in a category the vendor named the same as an OpenMV category sits alongside the OpenMV ones, and a new category becomes its own submenu. They are filtered to the boards they support like any example. See Scripts, examples, and the documents folder.
  • Models. A repository’s models appear in the Model Zoo, merged into the browser tree the same way, with the vendor’s own descriptions.
  • Stubs. A repository can ship .pyi stub files so the editor offers completion, signatures, and documentation for the functions its firmware adds – the same completion you get for OpenMV’s own modules, for a vendor’s custom API.
13.1.16.6. Authoring a repository#
A repository is a folder named for the vendor, holding a config.json manifest and a subfolder for each kind of content it provides:
acme/
  config.json
  firmware/
    settings.json                 board descriptions
    ACME_CAM1/                    one folder per board, named by boardFirmwareFolder
      firmware.bin
      romfs0.img
  firmware.version
  examples/
    index.csv                     which examples show for which board / sensor
    01-Getting-Started/           numbered category folders, same as OpenMV's
      hello_acme.py
      read_sensor.py
    02-Acme-Widgets/
      spin_widget.py
  examples.version
  models/
    index.csv                     which models show for which board
    acme/                         a group; its index.html + image describe it
      index.html
      person_detector/            one folder per model
        person_detector.tflite
        person_detector.txt       class labels
  models.version
  stubs/
    acme_hal.pyi                  a module the firmware adds
    csi.pyi                       overrides OpenMV's to add methods
  stubs.version
The folder name is the repository id: lowercase letters, digits, - and _, starting with a letter. Every part folder is optional; ship only what you have. Beside each part folder is a <part>.version file holding a single version string (1.2.0) that the IDE uses to decide when an update is newer.
13.1.16.6.1. The manifest#
config.json names the repository and, for each part, points at a downloadable archive:
  "name": "acme",
  "displayName": "Acme Robotics",
  "homepage": "https://acme.example",
  "configUrl": "https://acme.example/openmv/config.json",
  "firmware": {
    "release":     { "version": "1.2.0", "url": "https://acme.example/acme-fw-1.2.0.zip", "sha256": "..." },
    "development": { "version": "dev-20260701", "url": "https://acme.example/acme-fw-dev.zip", "sha256": "..." }
  "examples": { "release": { "version": "1.1.0", "url": "https://acme.example/acme-examples-1.1.0.zip", "sha256": "..." } },
  "models":   { "release": { "version": "1.0.0", "url": "https://acme.example/acme-models-1.0.0.zip", "sha256": "..." } },
  "stubs":    { "release": { "version": "1.0.0", "url": "https://acme.example/acme-stubs-1.0.0.zip", "sha256": "..." } }
name must match the folder name. configUrl is the address this same file is hosted at; the IDE re-fetches it to check for updates, so omit it only for a repository that will never update. Each part has a release channel, and firmware may also have a development channel used by Install the Latest Development Release. Release version values are compared as numbers, so a higher one is offered as an update; development versions are compared only for change. The sha256 is optional but is verified when present.
Each url points at a .zip (zip only). An archive holds exactly one top-level folder, and the IDE installs that folder’s contents as the part – so the firmware archive is packaged like this:
acme-fw-1.2.0.zip
  acme-firmware/           one wrapping folder; its name does not matter
    settings.json
    ACME_CAM1/
      firmware.bin
      romfs0.img
and unpacks to the firmware/ folder shown earlier. The examples, models, and stubs archives are packaged the same way – one wrapping folder holding what would sit inside examples/, models/, or stubs/. The wrapping folder’s name is ignored; what matters is that there is exactly one. Zipping the files at the archive root with no wrapping folder, or wrapping them in more than one folder, will not install. The simplest way to get it right is to zip the folder itself – select acme-firmware and compress it, rather than selecting its contents.
13.1.16.6.2. Boards, examples, models, and stubs#
firmware/settings.json uses the same board-description format as the firmware the IDE ships; add a boards entry for each of your boards. A few rules are specific to third-party boards: boardFirmwareFolder must be unique (it is not yet used by OpenMV or another vendor, since it names the folder your binaries live in), each board must carry its own firmware_version (this is what drives the update-on-connect prompt), and a board may set boardFirmwareFolderAlias to an OpenMV board’s firmware-folder name to inherit that board’s stock examples and models – the escape hatch for a board that is firmware-compatible with an OpenMV one. Reusing OpenMV bootloader identifiers is expected (they carry the signed Windows drivers); an app identifier that collides with a built-in board overrides that board, which the Override warnings panel reports.
Examples go in numbered category folders like OpenMV’s (01-Getting-Started); a category you name the same as an OpenMV one interleaves into it, and a new name becomes its own menu section. A model is a folder holding its .tflite and a matching .txt of class labels, grouped under a folder whose index.html (and an optional image) is the description shown beside it in the Model Zoo. examples/index.csv and models/index.csv are the same board- and sensor-filter files OpenMV’s own examples and models use, matched against your example and model paths, and decide which of yours show for which board. Stubs are ordinary .pyi files; the IDE hands their folder to the language server so they resolve alongside OpenMV’s, and a stub named for an existing module (csi.pyi) overrides that module’s completion.
13.1.16.6.3. Publishing and updating#
To publish, host the config.json and the archives it references at stable URLs and give users the config.json URL to install from. Anywhere that serves plain files over HTTPS works – a web server, an object store, or a code host. To ship an update, upload new archives, bump the affected version values in the hosted config.json, and the next time each user’s IDE launches it offers the update. Users who installed the repository through an installer instead get updates the same way, as long as the installed config.json carries a configUrl.
13.1.16.6.4. Hosting on GitHub#
GitHub is a convenient host, and the IDE fetches from it the same way it fetches its own resources. There are two pieces to place: the manifest and the archives.
Keep the config.json in a repository and give users its raw URL – the address the file is served at directly, not the GitHub page that displays it. The Raw button on the file shows it; it has the form
https://raw.githubusercontent.com/<user>/<repo>/<branch>/config.json
That raw URL is what a user pastes into Install from URL, and what you put in the manifest’s own configUrl so the IDE re-fetches it to check for updates. Pointing it at a branch (main) means pushing a new commit publishes the change; pointing it at a tag pins users to a fixed version instead.
Host the .zip archives as release assets rather than committing them – releases are built for binary downloads, so a multi-megabyte firmware bundle belongs there, not in the repository’s history. Attach each archive to a GitHub release and use its download URL, which has the form
https://github.com/<user>/<repo>/releases/download/<tag>/acme-fw-1.2.0.zip
in the manifest’s url fields, each with the archive’s sha256. Shipping an update is then: attach the new archives to a release, edit config.json to point at them and bump the versions, and commit. The IDE picks up the change on its next launch (the raw file is served through a cache that refreshes within a few minutes of the push).
